Water getting in foot??
fish2day
I have a 1991 Johnson 200hp that is getting about 1/2 cup of water in the foot each trip. Is this a seal behind the prop? And, is this hard to replace or should it be done by a Tech?? Will this damage my foot if I keep the oil changed?? Thanks
__________________
gokart83
Re: Water getting in foot??
Since Water and oil dont mix, Its def not good. If one seal is gone you should go ahead and replace all of them to be safe as gears and such gets very pricy! The cost of a seal kit is pretty cheap for anthor 21 Years.
boobie
Have it pressure and vacuumed checked before you do anything. This way you'll know exactly where it's leaking.
Chris1956
Honorary Supreme Mariner
Fish, That gearcase has 5 seals. Propshaft, drivshaft, shiftshaft and drain and fill gaskets. A pressure test may show the culprit(s).
