Shift Cable Bellow?
lrlima
1993 4.3 OMC<br /><br />Just pulled drive to replace seals and cracked exhaust bellow. While I was ordering parts, I figure I would go ahead and replace the shift cable bellow as well (drive bellow was recently replaced). When looking at the transom mount diagram on doug russel, I cant seem to find the drive shaft bellow on there? Can anyone point me in the right direction so I can order the part? <br /><br /><br />
index.cfm
Don S
Re: Shift Cable Bellow?
There isn't one on OMC Cobras. They used a hose from the inside of the transom shield that you just keep above the water line.
lrlima
Thanks Don S. I thought I was starting to go a little crazy...
