Ok, here is what I did and what happened.
I took Drive off and replaced impeller and housing. Also found the shift shaft seal going bad so I replaced. I have replaced impeller and housing before and never had a problem. But now when I fill with fluid it comes out the weep hole. So my question is, does anyone have any idea what I did wrong? Also, how do you see what seal is bad when you pressure test the outdrive when its together. Is there a way to separate the upper and lower and do the pressure test so you can see which seal it is? I guess what I'm saying is if I do the test, than how do I know if it is coming from shift shaft seal or by the impeller when its together?
Any help would be great. Thanks in advance.
