This problem has stumped all of us on the dock so I'm reaching out. My 1985 Volvo-Penta 225D (5.0 liter Chevy 305 CI) is having an ignition issue. The engine will not start, fire or run with the coil wire placed properly into the distributor cap. However, when the coil wire is held close to the distributor cap as when checking for spark, the resulting arc will cause the engine to start and even run. This arc occurs while holding the coil wire approximately 1/4 inch above the coil wire opening on top of the distributor cap.
Again, while arcing into the cap the engine will run. Putting the coil wire back into the cap will cause the engine to die and no longer fire. I have replaced the coil wire, coil and HEI retro fit for Prestolite distributor in an attempt to remedy this issue. The problem preceded the replacement parts.
Has anyone have this happen and how in the heck did you fix it. We're baffled. Thanks!!
