mercuiser interrupt switch adjustment
drotti2004
I have a 1968 mercruiser 160 and it will not go in to neutral from forward unless I go in from a higher speed reverse works fine, I tested the interrupter switch and its is good could it be out of adjustment if so could someone tell me how to adjust the interrupter mechanism?
Thanks
achris
More fish than mountain goat
Re: mercuiser interrupt switch adjustment
The switch arm needs to be bent. The correct setting is for the arm to move 1/8" to activate. Set a multimeter up on the switch and push the arm until the switch closes. Using a 1/8" drill bit check the gap between the roller and the middle of the switch activating arm (the bit that moves).... Adjust by CAREFULLY bending the arm...
attachment.php
drotti2004
attachment.php
Thanks for the help I will check it and let you know how things work out.
