Re: Can someone help identify part number???
I have a 1983 OMC with a 5.0. The tilt motor has disintegrated, and I'm looking to buy a replacement. I am having a problem finding one with the longer shaft shown in the picture. Can anyone help?
Howdy,
Welcome aboard!
Well, you might need to provide a little more info so your drive systems can be identified.
I did a little looking around at BRP (OMC sterndrive) parts and I found that just about ALL the stringers use an OMC#
0982706 tilt motor
You can use the above number in a google search to find many online dealers selling it.....
You can also go to
http://epc.brp.com and view part numbers for almost ALL OMC stern drives. (you don't have to put in your email address if you don't want to....)
Once you find your correct model number you can view the parts for it. There's several models for each year and while I didn't look at all of them the same tilt motor tilt motor is used for several models over several years..
Regards,
Rick
