120hp Johnson VRO Tilt issue
Sincs-64
Hi guys,
I have a 120hp VRO motor with tilt issues, I'm not sure on year, I am guessing around the late 80's.
It tilts all the way up no problems, but tilting down the hydraulics wine over but the motor stays up until the sequence hits the "trim" rams then the motor drops freely until it catches up with the trim rams. Also one ram drops all the way to the bottom first then the second ram follows. Any help would be greatly appreciated.
Thanks.
boobie
Re: 120hp Johnson VRO Tilt issue
You may have something binding up in the tilt tube area. When's the last time it was greased ??
