1991 mariner 75 lost all power but still runs????????? is it the stator?????
diverib
hi i have a 1991 mariner 75 a couple of week's back it was running well then just lost all power ?
i've cleaned the carbs (they didn't need it) changed the plug which we're very sooty
checked the fuel enricher valve
and it's still got no power but runs but will flood if i open the throttle to quick?
now i've been told it might be the stator but before i change it i would like to exhaust all the other things first as the're not cheap!
any suggestion's would be greatly received
rob
diverib
Re: 1991 mariner 75 lost all power but still runs????????? is it the stator?????
after lot of reading on here and on cdi electrics i have a few more things to try?
it seems to sound like it is the stator high power windings but will first try these few other idea's first!
1, clean all connections
2, disconnect the tilt/trim switch
3, disconnect each cylinder while running just to check its not a coil or lead
4,take it to the mechanic and get it fixed !!!!!!!!!!! lol
rob
