mayberetired
- Apr 18, 2012
- 2
The original issue was that the battery was not being charged, so prior to fishing trips, I just made sure the battery was fully charged.
After discussion with a local dealer, I replaced the rectifier at his recommendation. After replacing the rectifier, I connected my VOM at the battery and found it to be charging @ 13+ v. at idle. However, when rpm's were increased, the voltage increased to upwards of 17 v. To prevent burning things up, I immediately removed the red wire from the rectifier (insulating it to prevent shorting) to prevent the battery from overcharging.
In trying to find a replacement voltage regulator, I have been told by two different parts sources that this motor does not have a regulator and that the rectifier is the only control this motor has for charging the battery. This, I believe to be in error, as to my knowledge the rectifier's only purpose is in converting AC voltage to DC.
I did locate one source that did provide a part number 12082A 1, but he was not certain it was correct for this OB motor serial number.
I would welcome any thoughts or recommendations toward a remedy to this problem.
