Hey everyone, I could really appreciate your help on this one. Saturday I took my boat to the local ramp to drop in to take it to my slip. I have a 97 sea ray 260br 7.4 bravo 1. I pulled up to the ramp, and got out disconnected the safety chain, installed drain plug etc. Well as i proceeded over the crest of the ramp there goes the boat, straight off the roller trailer and onto the concrete.
Apparently, the brake on the electic winch was backed off. With the help of many good samaritans we were able to get it back on the trailer and off I went. So here are my problems. The outdrive is the only thing that took the impact. The boat basically slid on that the entire way. My outdrive was in the straight position but upon contact it was slammed to the left side. Now after a few days i see my gear oil supply line is leaking when outdrive is turned to the left.
Prior to this mishap I was unable to move my outdrive by hand but now if I get in the boat and turn the wheel so the outdrive is center, I can push the outdrive to the left by hand but not to the right. However, It runs, tilts, goes into gear, and steers. My questions are why can I now move my outdrive by hand to the left side only and what is the process to repair this? Also, the oil supply line, Whats entailed with repairing that? I( attached a photo for laughs)
