Re: No Gas to Carb
Your questions confuse me a bit.
When "looking down the carb" you should see nothing but air and fuel vapor...which is essentially invisible. You should not see fuel. This is entirely normal, whether engine is cranking, running, or sitting there shut off. The fuel itself is inside the float bowls hidden from view. You can't see liquid fuel in a carb without opening up the float bowls.
The only time you would see a shot of fuel going in by looking down the air horn is the moment you pump the accellerator...at that moment you should see a quick primer shot of liquid fuel (no need to crank engine or have the ignition on or anything...just pump the gas while looking down the carb). Of course this assumes there is fuel in your float bowl, and your accellerator pump within the carb is functioning properly.
You have a mechanical fuel pump, so if fuel is indeed not reaching your carb, it would absolutley not be the result of an electrical problem.
Quick summary of how to test a mechanical fuel pump...1. disconnect fuel line at carb, put the end in a container to catch fuel. 2. Crank the engine. Fuel will squirt out if the fuel pump is working...and if there are no fuel delivery problems between the tank and the pump. Take fire hazard precautions...disable ignition/etc before doing this.
If fuel does not squirt out when you do this, it still does NOT necessarily mean your fuel pump is the problem. This link shows good methods of how to properly test the remainder of the boat's fuel delivery system before the fuel reaches the pump:
http://forums.iboats.com/showthread.php?t=283269
Are you 100% certain you have a fuel delivery problem? Or do you simply have a no-start problem and are guessing that it is a fuel delivery problem?
Do not blindly replace parts...way too expensive. Troubleshoot, diagnose, and determine the problem first, THEN replace the necessary part if it actually needs to be replaced...
