frankttaylor
- Apr 3, 2012
- 100
Hello all,
Hopefully you can help! I recently purchased a boat that had been in a barn for 7 years. It is a 1990 Bluewater witha 3.7 L Mercrusier. The out drive is an Alpha I and Generation 1. Since it had been sitting for 7 years I felt it prudent to change impeller. The out drive was in remarkable condiiton with very little corrosion and required little clean up (this was my first time attempting this). Once we buttoned it all up and added oil we tested it and everything seemed to opertae correctly with no Leaks. The out drive was left in the lowered position until last weekend when I needed to move the boat. I tilted the drive and moved the boat and some time later noticed oil leaking from the seam where the upper unit and lower unit meet. Ideas on what the cause is?
Thanks,
Frank
Thanks,
Frank
