75 omc 165 hp changes coil, wires, cap, rotor, points, and condensor still no spark
tanksmith
after changing just about everything I still have no spark. checked volts at resistor have 11 going in and only 4 coming out could my resistor be bad.
Don S
Re: 75 omc 165 hp changes coil, wires, cap, rotor, points, and condensor still no sp
Resistors normally fail by going open, How did you measure that 4 volts coming out? Red test lead of your meter on the output side of the meter, black test lead on a good clean ground. You do not measure from either side of the resistor, that is just a voltage drop test.
Also, charge your battery, 11 volts is a dead battery and will not turn your engine fast enough to start.
