mercury 150 overheat
Tomthd
Hey anyone who can help. I have a 150XR2 mercury that overheats all the time and it seems I see that a lot. I am in the process of changing the poppet valvue and noticed that mine looks like half a poppet valvue. I saw how to put one on on-line and there was a smaller side to it that had a water line to it. I do not have this and the hole is plugged and no place for exsisting bolts to fit even if it were there. Is that something that changed with motor? I don't see how it works with no water line going to the valvue. HELP.
Re: mercury 150 overheat
Ayuh,.... Welcome Aboard,.... Have ya changed the Impeller yet,..??
I'll move this to the Merc outboard forum for ya,...
Faztbullet
You have the old style cooling system and only use the 2 bolt cover on poppet valve. It has the extra part of plates cut off at factory. How do you know its overheating ??? Are you getting a hot alarm buzzer or using a gauge????
