truckermatt
- Mar 29, 2009
- 384
Last year I changed my Master cylinder on my surge drum brake trailer. because it would leak brake fluid. Well the leaking stopped, but i still have no brakes.
I bleed the brakes after install,, and some fluid did come out but was a brown rusty sludge type. So now I want to replace the brake like and start fresh, the previous master cylinder was leaking for years before i bought the boat.
I see kits that have flexible rubber lines, do they hold up well.
http://www.easternmarine.com/20-single-axle-disc-drum-flexible-brake-tubing-kit-80326
Currently I have a steel line from MC that runs inside frame channel and down the axle, then splits off to each wheel.
I want to keep it simple, and I have never installed brake lines before. I dont have flare tools and such.
Would you go with flex line or get steel line again ?
