eggslinger
- Mar 13, 2012
- 2
Hello, I am getting a 1986 Suzuki DT2 running for a friend. I had to pull the flywheel to trouble shoot the ignition because there was no spark. I've got that fixed but I'm not sure to to set the timing and the points. There are 3 marks on the top face of the flywheel at one of the 2 openings but I'm not sure which one to use or the point gap.
Thank you very much if anyone can explain the procedure.
