NMEA wiring question
Pbguy420
I swear I'm almost done haha. Wiring question involving connecting my gps to VHF for dsc and other functionality I don't yet know about ....
Both have a wiring diagram but its not too descriptive so I need clarification
VHF has the following
NMEA out
NMEA in
Gps in
Ground (separate from power ground)
External speaker pos grd
Gps has
NMEA in
NMEA out
Comm 2 rx
Comm 2 tx
Power/grd
Alarm?
So do I just connect the NMEA wires to their opposites (ie- VHF NMEA in to gps NMEA out) then connect VHF gps wire to gps' comm 2 tx?
Sent from my iPhone using Tapatalk
dingbat
Re: NMEA wiring question
Connect in to out, etc. You don't need the Comm 2 connections
Pbguy420
Ok now I noticed that the VHF isn't labeled I'n out its labeled NMEA out pos, NMEA out neg--- both are labled out?! While the gps has NMEA out, NMEA in
I'm confused again lol
NYBo
What are the makes and models of the two devices? Do you have the owner's manuals?
dennis461
Simple,
connected correctly it will work.
Connected in reverse, it will not work and will not damage equipment.
etracer68
Ensign
Go to Uniden's web site, you can download a PDF of the owners manual. My manual tells the colors of both units wires, and how to connect them. Chartplotters use more wires, so the Vhf can talk to the gps also. If you just want vhf to know gps location, your gps should have a blue (output) wire, and it connects to the green (gps data in (+)). Then ground vhs to gps. Seems the NMEA outs are for chartplotter hook up. Hopes this helps.
etracer68
Ensign
Does the "Thanks guys" mean you got it wired up, and it works? Just curious.
