I have a 3cyl 70hp merc.1983.with no spark on one cyl.I have a CDI outboard ignition troubleshooting book and a DVA adapter and have come up with the following test results but can come to no conclusion.Any advise would be appreciated.Resistance on trigger wires disconnected,Br 1150 White 1220 Violet 1228 to Black and white wire.Resistance on trigger wires to engine ground while connected Brown 15k ohms White 15k ohms Violet 15k ohms. DVA readings at cranking speed connected . from black and white to Brown 5.7 White 5.9 Violet 5.2 .. Same test wires disconnected Brown8.5 WHITE 10.6 Violet 7.6 ..I switched the coils around but the same cylinder still no spark.I tested with a spark tester set at 7/16inch and the two cyl that fire have good spark. replaced secondary wires.Took apart and cleaned all grounds and connections.Checked insulation on all wire,all good,no shorts.Took yellow wire off rectifier ,still no spark one cyl.Don,t know much about these ign systems ,leaning toward switch box,any advise..Thanks.
