Finding the fuel cap?
plztellme
I have a 1990 Starcraft (Heritage 1600) 16 ft. open bow. I have an in boat gas tank, but don't know where to put the fuel? There are two plastic caps on the aft decking and one is for the emergency fuel shut off as it is printed on the cover. The other cover doesn't have anything printed on it. Could this be where the fuel is added? In addition, does anyone know where the fuel water seperator is?
barato2
Re: Finding the fuel cap?
the fuel water separator will be in the fuel line from tank to motor, probably near the motor somewhere. it may not have one, as not too many boats of that size come from factory with one.
when you remove the 2d cap, does it look to be a gas filler inside? can you smell gas or rotten gas when you put your nose up to it? have you called the seller and asked? finally, post some pics of the two caps and we're more likely to be able to help ya.
plztellme
Hey barato2, I finally was able to contact seller, and lo and behold he knew right where the fuel filler was.:) Duh!!!! Why didn't I think of that?:redface:
