1996 Johnson V4 Powerhead Removal: dowel pin?
WillG
J130TLEDM
In the process of removing powerhead on 1996 Johnson V4. I'm pretty sure that I have removed all bolts/nuts required, but still can't crack the seal on the powerhead. When I went back over the motor to see if I had missed any bolts, I noticed a dowel pin on the upper stbd side that looks like it could be holding the crankcase assembly together. The SELOC manual does not mention this dowel pin in the teardown instructions. Anyone know what I'm talking about? Any help would be much appreciated! Thanks.IMG-20110926-00060.jpg
daselbee
Re: 1996 Johnson V4 Powerhead Removal: dowel pin?
That dowel pin has nothing to do with the removal of the powerhead from the midsection. It provides a block to crankcase alignment point for re-assembly.
Look for missed fasteners.
WillG
TYVM Daselbee.
WillG
Found two missed fastners middle of engine block! one of them was under the carbs...:redface: My experience with this teardown: if there is any resistance at all, you've missed a bolt somewhere...
daselbee
Did it lift right off? Or was there also considerable resistance from the gasket? That gasket can provide quite a hold....
