My AQ125A engine has been surging on the water and I suspect either the fuel system or ignition system. However, the boat is very old and ignition system problems are preventing me from starting so I can check the fuel line vacuum (according to HOW TO: Testing your boats fuel system).
The high tension wire from the coil is sparking but I do not get spark through the distributor (Bosch 0-231-178-017). The rotor is badly worn, it can be seen below. This distributor does not appear to be a stock part, Volvo Penta Exploded view / schematic DISTRIBUTOR, for the Volvo Penta AQ125A; it also has the points replaced with a PerTronix or HotSpark electronic ignition.
At the moment, I am simply trying to find a replacement cap and rotor for the Bosch 0-231-178-017 Distributor; I have called NAPA and they are unable to find the part #. Can you offer a suggestion of where I could or should be finding this?
Thank you in advance!
