beason
- Mar 15, 2011
- 338
So i posted up this thread a few days ago.
http://forums.iboats.com/showthread.php?t=514134
(1999 Sea Ray 180 with Mercruiser GM 3.0L engine and Alpha 1 Gen 2 outdrive)
I think i found my leak. I was out this evening looking at something completely unrelated, and spotted this torn bellows. I can only assume it is for the shift linkage.
I planned on having the gimbal and bellows replaced on the off season this year, but it seems i need to step up the schedule on this one. Unless there is a way i can glue it back together, until boating season is over. (month or so?)
Now, I have the service manual for both the engine and lower. I have skimmed over them, but haven't really studied them. This is my second boat, and will be my first ever attempt at fixing anything mechanical with them. Before i even start, can i do this by myself?
I have decent mechanical skill, and can do brakes, oil changes, and replace parts on cars, i just have never messed with boats.
Please give me any advice you have. I am all ears.
Also, back to the original reason i was out there.
Is this the gimbal grease fitting? It seemed loud last outing, and putting some grease on it isnt going to hurt anything, so i think that is what i want to do.
I put some in there, just because its a grease fitting and any grease is better then none, but i only put a pump or two in there. I think it needs more. The pivots, i greased until they firmed up. I also put some in the bearing buddies.
Thanks in advance
Blake
Thanks in advance
Blake
