Milky Lube
davepnc
Hi All,OK i'm not going to panic but why is the lube in intermediate unit on 82 stringer 400 look milky after running in driveway?is this normal,looks fine when cool and sitting for a while.thank you for any help.
coupza
Re: Milky Lube
I am new to this, but I have been doing a lot of research. Milky lube would suggest water is getting in, but I also read that this can also result from bubbles forming from the motion of the gears. If the lube returns to its usual viscosity after a while I suspect you are alright.
Also, water is denser then oil so if it sits for a while and you pull the bottom drain plug water would come out before lube (this is a quick check and make sure the top plug is in while you pull the bottom one).
Howard Sterndrive
Re: Milky Lube
yeah, there's only a few ounces in the intermediate and two tapered roller brgs turning at engine speed, so it whips the lube up like a blender. You can pressure test the intermediate to 3-5 psi to test the ball gear seal if concerned, but don't give it a whole lot of pressure, as the top gasketed cover only has a few small screws holding it on as I recall.
