Bimmer540i
Thread starter- Joined
- Sep 6, 2011
- 1
Hi I have a 1973 mercury 150 hp I baught the boat and motor... the owner said it needed only throttle cables to be adjusted so I got that done well. Put it in the water boat has no reverse n goes trolling speed in foward when I try to go faster engine revs n boat stops .. had a mechanic come look at it he said it was the prop n put a new one has the same problems. Now he said its the lowwer unit ...
Ps. Out the water with earmuffs on the boat.. when I put in reverse it spins and when I put it in foward it spins .. when boat is off it locks in foward and iin reverse when spinning by hand n spins frreely in neutral
