Hi all, have a Johnson 115 hp 1979 and need to rebuilt power head therefore need to remove it. Removed all nuts & bolts as indicated by Clymer Shop Manual, and is as follows; removed exhaust plastic covers, removed nuts at rear of power head to adapter housing. Removed screw & nut at front of power head on each side. Removed 3 long screw on each side holding power head to adapter housing. Following all the above the power head it's not moving, checked for additional bolts or nuts and can not see any. Can any one help ? would be appreciated.
