Re: HELP!! engine stops as soon as it takes a load
My 65 HP did the same thing. It ran great on the muffs at home, but when I put it in the water, the fast idle lever wouldn't make it idle very fast, and when I would shift it into gear and try to give it throttle, it would just die. When I got it home, I pulled the bowl plugs on the carbs and I could see that the high speed jets were all completely plugged with gunk that had been in the float chamber. A good overnight soak in carb dip will do wonders. You said you did carb kits, but did you soak the jets and carb bodies with the core plugs removed? Ever since I did that, my motor idles like a dream, and has full power at takeoff.
Oh, BTW, which motor are we talking about here? Please post a model number.
