Tafflad
- Oct 23, 2007
- 536
I have a 4.3L Mercruiser (carb) 2007 with Alpha I drive
It has low Hrs, runs well and has full servicing.
This Q relates to Audible alarm .. i.e the buzzer than sounds when you turn on ignition, before engine starts.
Went out for nights skiing .... it last 30 min or so, had the audible Alarm sound as less than 1/2 sec beep ... twice.
Other than that worked fine, as we brought boat back onto trailer as we started trimming up drive the Audible alarm started sounding - continuously ... trimming drive back down made no difference.
As we had finished for the night ... left it at that.
When I got home - usual run on muffs .. and now Audible alarm sounding permanently.
Oil pressure, water temp & charging all OK.
Water flow out of engine is OK.
What would cause this Audible alarm ?
