Re: 1987 force 125hp
First, I believe the special thrust washer comes with the Vortex hub kit, but since I bought my prop and hub used off ebay, I don't know for sure.
I do know that the Vortex aluminum does load down my engine a good bit more than stainless props. It runs a good 500-600 RPM slower.
If you are experiencing a lot of Ventilation/cavitation try a cupped prop. It may not solve the problem but will at least help a little. I have that problem on my cuddy and while a cupped prop does not solve the problem, at least I can now use about 1/3 of total trim travel as opposed to none before.
On that note, I have had good success with a Ballisic stainless. It has very high rake and you must do a couple of modifications to clear the exhaust snout. You must remove the anode and substitute a stainless clamping collar for the thrust washer. I did a report here and in the Force forum a couple of months ago and if you search for them, you can find the photos included showing how to fit the Ballistic. If you don't mind spending the bucks, that might be the way to go. Again, I bought the Ballistic new/used from Cabelas and it was for a different brand engine--I think-- No box! It wobbled on the prop shaft and when I contacted Michigan with its number, they sent me an OMC hub. Thus, I can not give you a specific number for your engine. It looked so pretty, that for 200 bucks I bought it on speculation whether or not it would fit my engine. My prop is 21 pitch and is number 335533. If you contact Michigan, you can probably find an equivalent 19 pitch.
Unfortunately, for some reason, I can not access photos in my manage attachments album-- It only lets me upload new ones---go figure. I would need to scan hundreds of photos in my thumb drives to find and upload the correct ones.
All Force props fit all force engines--dual exhaust or single exhaust. There is NO loss of performance when using an open hub prop on a single exhaust engine.
The anode is held onto the "spool" with two fillister head slotted screws. No damage is done removing it but if you boat in salt water, you have less protection.
