sportcraftboaty
- Jul 31, 2011
- 3
This may sound like a silly question but I have to ask.
I have an older (1998) Sportcraft Fishmaster 180 with an aluminum RDS Manufacturing, 60 gallon fuel tank. My fuel guage stopped working so I checked the wiring at the sender. The ground wire was detached due to age and vibration over time. It appears to be the original wiring and connection. I have reviewed other fuel sender postings on this site and I have also looked at instructions on the Moeller website to make sure I am connecting things properly to avoid problems due to the close proximity of the wiring to fuel and possibly vapors.
All of the information I have found so far tells me that the ground wire should be attached to one of the screws holding the sender to the tank. I noticed a metal tab on the top of my aluminum tank and would like to know if this could also be used, or was intended to beused, as a grounding point.
The guts of my boat are opened up and I don't want to wait until Monday when I could call RDS to ask them. Does anyone know what this metal tab is for?
Thank you!
Thank you!
