84 evenrude 235
garymontgomery
i overheated. i checked the compression and it was 60psi on all cylinders with the throttle at idle and 90 with it open. ok?
should there not been a overheat buzzer go off when it over heated? there are two potted wired plugs in the heads. are these the sensors? can i short to ground to see if a buzzer somewhere goes off?
