Hi All,
Just finished replacing condensers and points and set up. Have also stripped and cleaned carb and replaced all parts from service kit, apart from the float (which floats well in gas and is not the old cork one)
The problem I have is that the engine will start and run fine at high revs only then dies after a couple of seconds. I have the low speed idle out 1 1/2 turns and have tried opening it and closing it and waiting but the thing still dies. I have a real problem starting it again only with choke fully closed. I then notice a small amount of petol leaving the front of the bowl.
As I say when its going it sounds perfect only it will not keep going.
Please help.
Thanks
Please help.
Thanks
