2004 Johnson 4 Stroke Outboard - Trim not working
RJackson
Hi All,
After using my boat with no problems for weeks already this summer I went to start my 2004 Johnson 4 Stroke Outboard (70hp) yesterday and it started right up no problem but I had no trim at all.
The battery has plenty of juice because the engine will crank and it starts flawlessly.
I tried the trim on both the throttle control and on the engine itself (there is a button that allows the user to do this) and nothing happened. There was no clicking or anything when the trim buttons were pushed.
I was able to let down manually after turning the release screw on the port side of lower unit. There was also ATF fluid in the tilt motor. My motor manual says that there are two fuses on the cowling, one of which is a 30 amp and is related to the trim electrical. I checked that fuse, it seemed fine, but I replaced it with a new fuse regardless and still the trim didn't work. I could not find the other 15 amp fuse under the cowling as per the engine manual despite almost 10minutes of looking!
Some specifics on the motor itself:
Model #: J70PLS0
Serial #: S 16027682
I'm at a loss -- I'm hoping that its not the trim motor itself because it looks to be about a $300-$500 part and I can't understand why one day it would work fine and the next day it would just "stop"?
Any help is greatly appreciated!!
Many thanks,
RJJ
boobie
Re: 2004 Johnson 4 Stroke Outboard - Trim not working
If it was me I'd ask this same question on the Suzuki forum as they built it for Johnson. I've worked on a couple of them but have no manual to help you out. Sorry.
