firehawk_14
- Sep 19, 2010
- 14
how does the bearin go back in ? 1 seal 2 bearin 3 small clip 4 big seal 5 big clip ????
gimble
ware the big clipp goes
firehawk, you need to tell us what you are working on. Since there is no such thing as a gimbal bearing on a 250 we are just guessing. Did you download the .pdf file I linked to? If not, download it an look at it. It's the instructions for the primary shaft bearings hoping that was what you meant when you said "Gimble"
The other problem, without knowing what engine you have, it's impossible to say which primary housing you have.
Either post some engine numbers or pictures of what you're working on.
