glastron 2003, No drain in the ski storage area
brick75
Re: glastron 2003, No drain in the ski storage area
Gonna need to be more specific here. Are you saying that it's not draining, as in it's clogged? Or that there is no actual drain installed in the compartment?
Old Don
My 2006 has a small hole in the front and rear bulkheads so it drains into the bilge. I had to run a rod through it under the fuel tank to clear it out. Drains fine now.
jillibn
sorry, no actual drain in the compartment. I've been told that the 2003's??? Can you help?
