wellcraft210
- Jul 17, 2011
- 3
hey guys/girls,
last ditch effort for a new idea on this problem ive been dealing with..
here goes...
I purchased a 2000 wellcraft sportsman 210 w/ a 150 johnson outboard in august 2010.
boat ran great during previous owners test run with me, and ran great for about 5 weeks after my purchase : ).
i topped the tank off with fuel, and the oil tank up with oil, and decided to take a long run that day, and this is what happened.
when the boat hit 34 mph (about 4k rpm) the check engine light comes on, full power, and audible. ease off throttle, alarm clears and its business as usual.
I ran the following the tests..
replaced water separator
cleared the vent
cleaned the fuel pump screen
replaced primer bulb
ran the boat. still alarms.
installed a vacuum gauge just before primer bulb and ran the boat, drew 5-6" and tripped. brought a kicker tank and connected to outboard while on the water..runs fine : )! now i'm sure i'd find it...wrong.
back in the driveway I ran a length of clear poly tubing from access valve (ball valve-no anti-siphon valve on my boat) to the primer bulb w/ my vacuum gauge in the system.. boat ran 2-3" : ). replaced all fuel lines. ran boat...alarm tripped!!!!
brought boat to the wrench..diagnose bad pick up tube (poly tube test proved that it was not the pickup tube in my driveway) so i changed it and removed t he screen on the end..never ran boat again for the season.. filled the tank (treated) winterized and waited..
spring start up i changed the pick up tube and usual start up procedures.. boat ran great for the first month. : ) i thought i was in the clear.
I filled the tank with fuel and oil tank with oil. and ran the boat..struggled to idle, and stalled at no wake speeds.. and once again 34 mph and 4 grand rpm..check engine light.
brought the boat back to the wrench. they diagnosed the vac switch for alarm was tripping at improper vac pressure..replaced.
finally some results. picked it up yesterday ran it.. check engine with new symptoms!
latest symptoms:
check engine light occurs (now at a 22mph and above- and one time at 18 mph)
primer bulb deflates (yes, i ran w gas cap open to check venting.)
I know i just told a life's story but i could really use some help with this one!!
thanks in advance!
here goes...
cleared the vent
latest symptoms:
thanks in advance!
