Re: 1988 Merc Black Max 135hp Charging problems
Fire your tech. She don't even know what to test. She was on one of the switchbox charge coil sets.
The device on the switchbox mounting plate is a bridge rectifier. One terminal is labeled +. The other two are stator connections. Make sure it's hooked up right. There's a FAQ on this site that has testing procedure for it.
The device on the top is a stator saturation regulator. It is NLA, probably because it's value is somewhere between useless and hazardous. (as in fire starting) If it's shorted it would take out a mercury rectifier in a heartbeat. If you put in one with decent parameters (ie radio shack 20 amp bridge rectifier) it wouldn't blow, but would probably ignite the regulator.
1. disconnect and test the rectifier with an ohmmeter and the FAQ I referred to. Replace if bad.
2. Measure the resistance between the yellow wires. It should be less than 1 ohm, but not 0. There should be no continuity (infinite resistance) between either yellow and ground.
3. When you re connect the rectifier, make sure the wires are on the right terminals.
4. Disconnect the regulator, at least for now, probably permanently.
If the stator is bad, it needs to be replaced.
Options from there
1. Install a fresh murkery rectifier, might as well stock spares.
2. Fit a better bridge rectifier.
3. Install a 16-20 amp regulator, commonly used on later engines in pairs. You only need one.
If you don't install a regulator, the battery will do the job. It will use some water doing it. If it is regularly maintained, it's life will not be shortened.
hope it helps
john
