Provincetown boater
- Jun 21, 2010
- 16
Hi
I have two problems with my 170 mercruiser.
1) yesterday I was 5 miles from my home port in Provincetown, MA traveling at about 3000 rpm when my engine suddenly began to overheat. as the temp quickly reached 200 I shut down and anchored up until the engine cooled down to to 160. I added some water to the cooling but didn't have enough on board to fill the tank on the top of the manifold. I was able to restart the engine but any attempt to increase power over 1200 rpm resulted in a quick climb to the temp. At the lower speed the normal temp of about 125 was maintained and I crept home with it. Once back in port I topped off the coolant tank with a 50 / 50 antifreeze mix and started out again, but as soon as the rpms went over 1500 the temp climbed very fast and I was forced to shut down. I again idled back and the temp quickly dropped down to normal and I was able to move around the harbor and get the boat back on the mooring.
So what is the problem? I had the upper unit rebuilt 3 seasons ago and had a rebuilt lower unit installed 2 years ago. I only put about 100 hours a season on the motor so I am surprised to be having this kind of problem. Do I have to pull the boat from the water to work on this? Am I looking at a big expensive fix? Or is it a simple blockage I can fix in the water?
2) Assuming I can fix the first problem, I have a shifting problem too. I few days ago I reset the shift cables as per information I got from this forum and the manual, I was having trouble shifting into forward. Now it shifts pretty good into forward and reverse, but it is very hard to get it back to neutral, especially from reverse which seems to come out of gear very hard and jumps back into forward before I can pop it back to neutral. With the engine shut down it shifts just fine. Is this something with the shift stall switch? is this switch adjustable?
Thanks for your help
Frustrated old boat owner - Pete
