Hello,
I have a 1987 Force 125. I recently did a compression check and all 4 cylinders registered about 88 psi; far below specifications. All 4 cylinders registered about the same. Any ideas as to what I should check first? Head Gasket? The boat seems to run fine, but only up to about 1/2 throttle and then will begin to cut out. It seems to run perfectly up to about 20 mph.
Thanks in advance for any help you can give me.
