I recently purchased a 1999 Charger Foxfire with Evinrude 200HP EFI and a MinnKota 70lb Thrust Trolling motor. I have only put it out on the water twice now, but only because of a (minor) issue. After almost 3 hours of being out on the water for the first time (by myself) I realized that I was standing in a puddle. Of course, I paniced and smashed to the nearest dock I could just in the case of a "sinker". Once at the dock I engaged the bilge pump. Water poured out of the bilge for almost 4 minutes, and when I pulled the plug after loading the boat even MORE water for almost an addition 2 minutes! So, let me start with explaining that this boat does not have any holes, gashes, scrapes. The gunwale is perfectly sealed. The transom is perfecftly sealed. SO, yesterday out on the water again. Everything fine, no water on floor. I was happy. Immediately after I loaded the boat to head home, I saw water everywhere. It poured all the way up and under the carpet to the front most storage bin. It's awful and when I pulled the drain plug water POURed for almost 3 minutes. What is wrong here? Can anyone give me some suggestions as what "I" am doing wrong or missing? By the way, I should mention below are pictures of what I am considering as a potential culprit. Could my problem be that both my livewells are filling up and overflowing out and into the bilge area. Which is (overtime) essentially flooding my boat. Notice the pvc valve at the top left of the picture. Shouldn't that be closed, not open? Thanks for your time and help.
