1970s 1150 mercury 115 hp top piston has metal plate over plug hole???
Wdr
Hey there I'm was givin a 16ft fiberform boat with a 115 hp merc on it... I was told that it's a 1971 but can't confirm thy yet. The engine seems to run fine... Rough idle but revs up fine. I pulled the top plug on this inline 6 cyl. And there is a small plate of metal covering the inside of the spark plug hole. It is not the top of the piston the cylinder has compression but very little because of the metal piece... The othe five cyl below dint not have this. I'm stumped and the only I an think of is that it is there to create crankcase pressure... Any help would be appreciated thanks. I'll post a picture later on
Chris1956
Honorary Supreme Mariner
Re: 1970s 1150 mercury 115 hp top piston has metal plate over plug hole???
That doesn't sound normal. The serial number will tell you the year of the motor. Look it up at the maxrules.com web site.
If you remove the top transfer cover (starboard side of motor) you will be able to see into the combustion chamber and see what is up.
Laddies
Banned
Thats most likely a reed valve that has broken and gotten into the combustion chamber, a broken reed would also a poor idle.
j_martin
It would have done some damage fighting through the transfer port.
Chris1956
Those pictures are too small to see. I would pull the transfer cover and see what is in there. It might be something wierd like Jimmy Hoffa's body...... I had a piece of a clam shell in my old Johnny Fat-fifty's crankcase. Didn't seem to bother it any...
daveswaves
Ensign
I have seen that a number of times, I can assure you its not Jimmy Hoffa, a reed valve or anything else that got sucked in. It is vaporized aluminum from the crown of the piston in that cyl. When you take it apart you will see a very eroded crown and likely a destroyed piston with stuck rings and melted aluminum on the cyl walls. It happens during detonation when the piston top is so hot it starts to melt and vaporize. At some point the molten mess splashes into the hole and cools. You can see the imprint of the spark plug in the metal "plug".
nwcove
you merc guys have a much better sense of humour than the omc guys, and im an omc guy! if you wanna get there first.....buy a merc! if you wanna get back home....buy an omc! lol (outboards are outboards.....love or hate em, they all have thier quirks!)
Wdr
thanks for the replys. i did a little more research on the motor it is actually 1975. i found an online manual that i downloaded and seems to me that the head and the block are all one piece. is this correct? whatever it is that has happened in that cyl i know it needs to come apart, so ill let you know what the problem actually is.
swamp-fox
Yeah I think daveswaves has it right. When you take it apart post some pics of what the inside looks like. So I can have a idea what mine looks like..lol..My 115 did that. I poked that "plug" out with a screw driver and used a magnet to get the pieces out of the cylinder. I figured that's what happend so I wheeled it to the back of my shed for later project.
Chris1956
Gee, if you remove the upper transfer cover, you can see the sides and top of the piston, the rings and the cylinder walls. You may even see the spark plug hole.
The head is non removeable, and tearing her apart before looking is dumb.
Wdr
i pulled the motor off of the leg yesterday. split the crankcase and sure enough the top piston had melted. daveswaves says this is caused by detination... any other possible causes? im ordering a new piston and rings for it this week after i get the cylinder wall all cleaned up just to make sure it is salvagable.
where do you guys find is the best place to buy your parts? im live in british columbia. going to call around for some prices.
Faztbullet
Make sure you re-ring the other cylinders and replace the trigger as well...
CharlieB
Also rebuild the water pump as the TOP cyl is the first to overheat as pump output is reduced and fails to keep the block completely filled.
Wdr
Yes I am ordering new rings and a new piston... The trigger? Which parts is this?
Yes the leg will get pulled aswell rebuild the water pump and check out the gears.
carholme
What is your engine s/n to confirm the year and send you the parts list?
Gerry
mr 88
Most of the Towers have a oil feed line that goes from the bottom of the block to your top cylinder.If that is pinched/sliced or free of the ftg it should be addressed as the result if not connected is usually a meltdown up top.What is the condition of your line? They have a tendency to break under the flywheel,no visible warning sign when they let go.A water pressure gauge is something else that you might want to add on.Replace plug by toasted cylinder with a 90* h2o Ftg. that cylinder is also the most likely to be the first to overheat from lack of water.
Wdr
Gerry
s/n 7055359
piston. piston has 3 rings
rings. for 6 pistons
timimg belt
rubber mounts. holding the cawling to the motor... have bolts coming out both side
powerhead gasket kit
waterpump kit
and that should be all the i think.
Wdr
the oil feed line that runs from the bottom of the block to the top was cracked and clearly needs replacment. how would that make the top piston melt down tho? doesnt that just feed the main bearing?
