I have de-potted the trigger coils, cut their traces, soldered leads to the + and -, and run them, along with extended charge coil wires, out from under the flywheel on the starboard side. It's all hooked up and hangin, so I can turn the engine over, and see if it sparks. The problem is, when I put the stator on, the flywheel hits something and stops. it doesn't sound like metal to metal, the thing is in neutral, and when I take the stator off, no interference. The stator is fully seated on the crank case, and I didn't take the coils off the core, so I don't get it. I have pics of this thing from three sides and the top, so if anybody sees something squirelly, let me know.
