Do you have to remove all 3 bolts under trim tab to remove lower unit?
M mike1945 Recruit Joined Jun 15, 2011 Messages 3 Jun 15, 2011 #1 Do you have to remove all 3 bolts under trim tab to remove lower unit? Last edited: Jun 15, 2011
O OMCdinosaur Recruit Joined Jun 13, 2011 Messages 5 Jun 15, 2011 #2 Re: 1991 evinrude lower unit Re: 1991 evinrude lower unit No 1 just holds the anode in place and doesn't have to be removed.
M mike1945 Recruit Joined Jun 15, 2011 Messages 3 Jun 15, 2011 #3 Re: 1991 evinrude lower unit Re: 1991 evinrude lower unit OMCdinosaur said: No 1 just holds the anode in place and doesn't have to be removed. Click to expand... Thank you
M mike1945 Recruit Joined Jun 15, 2011 Messages 3 Jun 15, 2011 #4 Re: 1991 evinrude lower unit Re: 1991 evinrude lower unit Got lower unit to drop but seems like something is holding it. Took out shift pin and the shift lever moves freely, any ideas.
