Hi,
My boat restoration job is going well, but I thought I'd ask here for some suggestions as to what material I could use to do a major repair to my boat's rudder.
The rudder is made of Fiberglass and was originally constructed by joining together two fiberglass "shells". These two halves, when joined formed a hollow space which was completely filled with some kind of hard, dense, putty or filler material. This putty was orange in colour and made the rudder very heavy, the whole thing weighing around 15KG.
In my over exuberant efforts to repair the rudder I ended up separating the two f/glass halves and removed all of the filling material by attacking it with hammer and chisel.
I intend to repair the rudder by rejoining the two halves using West System Epoxy resin and F/glass cloth but am not sure what material or I could use to refill the hollow space. Should I use epoxy resin mixed with microfibres as the filling material? Or could anyone here make suggestions as to what product I could get to do the job? It would need to be in a liquid form to be able to pour it in and fairly dense to give the rudder some weight and rigidity.
Here are some pics of the rudder to show what I'm on about -
Cheers,
bluey.
Cheers,
bluey.
