5.0 Gi Pumps doesn't runs
fabio
Hi everybody! I have enough gasoline, but the pumps doesn't runs properly. It seems that the low pressure pump doesn't feed the high pressure; it begins to whistle, more throttle I give. And the engine shut off. I replaces all the pump body - 2 pumps with the filter - but nothing changed. Can it be a problem of the ECU?
fabio
Re: 5.0 Gi Pumps doesn't runs
I removed the main gas line from the tank, and tested with a small tank directly in the filter. No way! It looks like the low pressure pump doesn't work ... but I tryed with a new one!
Don S
What is the full model number (the letters after the 5.0Gi), or the serial number of your engine.
Don S
5.0GIPEFS is the full model number for your engine.
Here are some test procedures for your fuel pump system.
  • EF TBI Fuel Pump Testing.pdf
fabio
Thank you! Tomorrow I will follow your procedure!
fabio
we have an error on the ECU ... 33! what does it means?
