1991 or 93 25hp 2 stroke Evinrude running rough and won't idle.
soulprogression
Hoping to get some help and ideas here.
I have a 91 or 93 (can't fully make out the serial number) 25 horsepower Evinrude 2 stroke that is running rough and doesn't want to idle.
What I have done.
Fully cleaned and rebuilt the carburetor, replaced broken/original full pump with brand new fuel pump, replaced the spark plugs.
The motor will start quite easily and runs ok at mid range to high rpm's. However, when I try to throttle down and let the motor idle it either bogs down and dies out or I have to give it gas to keep it running. When running at low rpm's (almost at idle) it sort of backfires and pops sending smoke out of the exhaust.
I kinda want to order a manual for it, but not knowing the year I am having trouble finding the right book.
I have been considering running sea foam through to see if this helps, but wanted to get some opinions first.
Thanks in advance for your thoughts/help.
Max
Cofe
Re: 1991 or 93 25hp 2 stroke Evinrude running rough and won't idle.
It may be a lean sneeze. Back the idle mixture screw out a little bit more.
soulprogression
Cool I will check it tomorrow, and thanks for getting back to me so quick.
I played with that a little but didn't go much further than a 1/4 turn. It is also quite loose, as in, after adjusting and starting the motor, it has a tendency to loosen up some more on its own....
Daviet
When you overhauled the carb did you remove the small welch plug on top of the carb and clean the passages inside?
Cofe
The idle mixture screw should not loosen itself. In this picture #13 is a oring that keeps the needle sealed from air in leakage, and holds it in position.
soulprogression
Ok to clarify, my dad pulled and overhauled the carb so I will have to ask him about the welch plug tomorrow. I have a feeling he left it alone though.
Also I was confused first thought you were referring to #1 when you said idle mixture screw. So the ims #13 is not loose, I have adjusted it, just did not know the technical term. I have adjusted it starting from 1-1/2 turns out all the way to 2-1/2 turns, 1/2 turns up, with little change in engine performance. I also tried dialing down and started at 3/4 out from seated, and then adjusted slowly up from there, again very little to no change.
#1 screw which is a jet correct? should be snugged down?
soulprogression
Bringing it to a guy today or tomorrow, hopefully he can figure out what's up and it won't cost too much, results soon.
