Sandbasstard
- Apr 25, 2011
- 1
I just recently aquired a Minn kota 101 XE. The control head seems to have a gear setup that turns the shaft. I've never seen anything like this before as I've always had a foot control. The problem is, the tiller handle is completely opposite of the prop, much like you would see on a transom mount setup. There has to be a way I can turn the control head around so I can use it on the bow of the boat. It is mounted in a bow mount at the moment. I'm sure it can be done, if anyone has any info about it I would really appreciate it. It will save me a bunch of time and broken parts I'm sure. Thank you.
