Re: Motor shuts off when I put it in gear???? 1993 130hp Volvo
There is about a thousand different reasons. If you were looking for a push this button fix for that problem, you are just out of luck.
Just to name a few possibilities.
Wrong timing, poor compression, water in the fuel, carb out of adjustment, spark plugs bad, needs a basic tuneup, vacuum leak, and on and on.
Would really help if you tell us what engine you have, not Hp and year, we need model numbers.
Also let us know what you have checked and replaced and know that is good.
