I bought a little bass boat over the winter, and it has a 1975 70hp Evinrude on it. I changed out the fuel in the tank, and drained all the lines and bowls. Put it on the water hose and it fired up great in the driveway, but it won't run in the lake. I sprayed carb cleaner in the carbs and took a small tooth brush to them. Then I could get it to idle in the lake, but it sounds very weak and can't handle the load of going into gear. It sound like it is flooding. It gets a real hollow sound and slows to a stop. I let it idle through 4 gallons of fuel with Sea Foam with no improvment.
I then took it home, checked the compression, and it has 118psi, 118psi, and 120psi. I checked the spark with an ignition spark tool, and all three have strong spark. I then let it idel in the driveway and pumped the primer bulb. There was no change in the idle. While it was still idling I pulled the plug wires one at a time. The #1 cyl showed no difference in the idle. The #2 caused it to run very rough and blew out a lot of white smoke when the plug was reattached. The #3 caused it to change a little, but also blew out a lot of white smoke when reattached. This leads me to believe that I have a fuel problem on #1 and possibly #3.
I then pulled the carbs and cleaned them. All of the passages seemed to have very good flow with no observed obstructions. It was dark by the time I was done tonight so I didn't get to the lake. I will test it tomorrow after work. Is there anything else that anyone can think of that I may have overlooked? Any help would be greatly appreciated. I have a fishing tourny on Sunday, and I really don't want to fight the wind in the pantoon boat again. Thanks.
