Need a new prop...HELP
freeboats
I have a 1983 Bayliner Capri (19') powered by a volvo penta AQ125a with a 270 outdrive
last year I chewed the prop up pretty bad on some gravel in shallow water, so I would like to replace it.
I took the old prop off and the only markings on it are Michigan 082032.
I think this is the original, its not in bad shape, just feel a little vibration and I do not want to damage the drive unit.
any advice???
steelespike
Re: Need a new prop...HELP
You should be able to get it repaired and the prop shop can tell you the size.
Someone may check in able to figure the numbers.
