Re: What grease do I pack my bearings with?
3. Use some emery cloth on the spindle where the seal rides.
I would never use anything abrasive on the spindle,,,,,, especially where the seal runs. Just keep it really clean. If it is rough, you already have problems. There are shims you can get to fit over the seal surface that may work for you. DO NOT use anything rough on the spindle.
If ANY WATER is found in your bearings/grease,,be sure to remove all the old grease, check seals, and repack the bearings if they are not damaged by the water. If bearings do have water in the grease and sit up for a while, the bearings will rust and probably need replacing. Cheap when you consider that a bad (rusted) bearing may seize and ruin the spindle if the bearing races spin on the spindle.
